ytsejam1138 ytsejam1138 is offline
ytsejam1138's Avatar
Default Re: Resolution problem - 10-06-2008, 01:55 AM
Originally Posted by melzbelz
When I reboot, the resolution resets to 800x600 and it usually does not switch to the higher resolution. Sometimes it does, sometimes not. I flashed bios hoping for a fix but no joy. I hope this fixed soon- it's a nuisance in a PC that is pretty much a pleasure to use.
I added a 16GB SDHC (from $46) and ordered 2GB RAM (from Crucial $40)
Mine also started to do this. I reinstalled the video driver and it fixed it. However, the icons repositioning is still a problem.
Video Driver via Dell's site: ... ile=264716
My Dell Mini 9
Black / BIOS A05 / Dual Booting XP Pro and Ubuntu 9.04 / 2GB RAM / 16GB SSD / BT 2.0 / 1.3MP Webcam / US-INTL Keyboard U061H
External Drive
Buffalo MicroSD USB Memory Stick w/8GB MicroSD
jbloodwo jbloodwo is offline
Send a message via AIM to jbloodwo
Default Re: Resolution problem - 10-06-2008, 01:58 AM
this must be a relay bad driver.... I think the vostro 1400 i have uses the same chipset and i will have the video drop to 800x600 sometimes when i take the unit out of sleep....
Dell vostro 1400
Dell Mini 9 8 gig ssd 1 gig ram .3mp cam
powerbook G4 ( needs to be refreshed still on 10.4)
mark62 mark62 is offline
Default Re: Resolution problem - 10-06-2008, 02:18 AM
its a horrible graphics chip
  (#14) Old
SecUnd3r SecUnd3r is offline
Default Re: Resolution problem - 10-07-2008, 10:53 PM
I have two Dell Minis, one for my wife and one for myself. I didn't notice this problem when we first received them (that doesn't mean they didn't do it), and since then I have removed the bloated version of windows home and installed a nlite'd version of Win XP Pro. I don't have a problem of repositioning icons or resolution dropping.
So, it could possibly be the windows XP home version they pre loaded, or possibly the order the drivers they are installed in.
  (#15) Old
Default Re: Resolution problem - 10-08-2008, 12:37 AM
Mine kept doing this where I had to reset the resolution too. I noticed the language bar kept coming back non stop too. When I stopped closing the language bar the resolution would come back to how I wanted it, not the 800/600 that it kept reverting to.
Let me know if that didn't make sense.
  (#16) Old
melzbelz melzbelz is offline
Default Re: Resolution problem - 10-09-2008, 07:20 PM
As suggested, I reinstalled the video driver and the resolution is no longer resetting to 800x600. I had also turned off the language bar, so the problem may be related to that. Very cool to have that annoyance fixed
Great little PC, especially since I bumped the RAM up to 2GB. Definitely worth the $40.
White Mini 9 with 2 GB RAM and 64 GB RunCore SSD running Win7 RC1
  (#17) Old
jdizzle jdizzle is offline
Default Re: Resolution problem - 10-12-2008, 12:01 AM
does anyone know how to make a startup path to the Intel graphics options themes? In other words at startup, a theme(1024x600) would load. kind of a hillbilly fix but really, I' m bettin Intel can't fix this or won't for a while.
Studio 1458 | Fingerprint magnet black Windows 7
Diztop D945GCLF2 | dual-core Intel® Atom™ processor 330
  (#18) Old
hcck3d hcck3d is offline
Default Re: Resolution problem - 10-20-2008, 05:59 AM
Wierd, I have not had this problem with OSX installed, but now that I have XP on one SSD, it makes it kind of hard to browse. Constantly sliding back and forth. grrrr
  (#19) Old
joshpape joshpape is offline
Default Re: Resolution problem - 10-21-2008, 09:58 AM
melzbelz did you install the driver found on the supplied driver cd or from the dell website?
Did this fix the icons rearranging everytime you turn on the mini?
  (#20) Old
DebDell DebDell is offline
Default Re: Resolution problem - 11-02-2008, 07:38 PM
My Dell used to always change resolution to the 1024 X 600(for the first few days). Now it just does it now and then. I never know when or why. I was very annoyed to hve to manually reset this. I downloaded a FREE program from called AutoHotkey and recorded the mouse and keystrokes to make the change. I saved the program on my desktop. Now when I start up my Dell Mini, if the resolution is wrong I just click the program icon and it is quickly fixed. It is less annoying.
« Upgraded Linux to XP - Unknown Device | CD Boot Problem »
