cookiemonster's Avatar
Default Re: Bluetooth Problems - 02-24-2009, 10:56 AM
Wait, you have a Mini 12? In that case, I think you may need R195925.EXE (see here).
If that doesn't work, try R195924.EXE, (see here), but I think this is the Battery Meter.
alhartman6 alhartman6 is offline
Default Re: Bluetooth Problems - 02-24-2009, 05:54 PM
Nope, none of those helped.
I had to reinstall Vista, turn the Bluetooth on and then reinstall XP Home and now all is well. It's stupid that the XP driver/Wireless Select Switch software isn't on a par with the Vista version.
Oh well...
« Mini going into standby mode after resuming from hibernation | Mouse unresponsive after boot »
