ZoneCruiser ZoneCruiser is offline
Default Battery indicator light - 10-01-2008, 05:27 AM
Does everyone's battery indicator light work? (next to white power indicator)
Mine has never worked since I got it out of the box.
Is it supposed to come on when the power adapter is plugged in?
mark62 mark62 is offline
Default Re: Battery indicator light - 10-01-2008, 06:38 AM
it only comes on when the battery is low and then it blinks... if it is charging when you have the mini on no light comes on,,, when you turn the mini off if it is charging the white light stays on....
jelli794 jelli794 is offline
Default Re: Battery indicator light - 10-02-2008, 04:44 AM
Under the hardware section of this forum there is a post that tells what and when the lights come on.
« Screen flicker/shimmer | Bluetooth Icon »
