Blue_Sassley Blue_Sassley is offline
Send a message via ICQ to Blue_Sassley Send a message via AIM to Blue_Sassley Send a message via Yahoo to Blue_Sassley Send a message via Skype™ to Blue_Sassley
Default 16GB SHDC and Ubuntu 9.04 NBR - 05-31-2009, 01:49 PM
I bought a 16GB Class 6 SDHC card for my Dell Mini 9 and I'm not able to get Ubuntu to mount the drive, does anyone else run Ubuntu 9.04 NBR and have a 16GB SDHC working?
baskie baskie is offline
Default 05-31-2009, 02:27 PM
Yep, 16g sdhc with 9.04 here, no problem, although it's on a eeepc 901 not the Mini9, so unless your card is the problem it might be a mini9 only issue.
Have you tried formating the card with gpart?
Indigo Indigo is offline
Default 06-02-2009, 11:38 PM
I have 9.04 NBR on my mini 9 and my Class 6 16GB SDHC mounts without issue.
Edit: I do have an off brand 4GB that will only mount if used with one of those mini USB card readers. Have you tried your card using that?
PDR60 PDR60 is offline
Default 06-04-2009, 01:09 AM
I've heard some problems on here with the Adata cards but I'm running a Sandisk 16 GB clas 4 card with any issues. I ordered a 32GB class 6 card off of ebay, I'll let you know how it goes.
Hers:Pink Mini 9|2GB|8GB SSD|16GB SD|1.3 Cam|v470 BT Mouse|XP Home
Mine:Black Mini 9|2GB|32GB Runcore|32GB SD|1.3 Cam|v470 BT Mouse|Kubuntu 10.10
Future Mods 64GB Runcore - BT Headphones
Default 06-04-2009, 07:31 AM
I could not see my SD card when I first installed Ubuntu 9.04 netbook however the instructions here worked perfect (see below). Even though it's not for the dell mini it worked perfectly for mine...
Dell Mini 9 --- 2GB RAM --- Runcore 64GB SSD --- 16GB SDHC
« OS Error Message SSD?? | Still pictures are all black? »
