minivista9 minivista9 is offline
Default Keyboard Help - 05-29-2009, 09:00 PM
For some odd reason my keyboard is acting all weird and sometimes will not work I took out some keys (they wont go back in) and I need to know if dell will send me a free keyboard or will I need to buy one?
How do I replace it?
Default 05-29-2009, 10:00 PM
The Dell Service Manual, available from the support site,shows how to remove and replace the keyboard. It isn't difficult. Dell may send you a new one, but they're only about $20 shipped to replace.
Richdmoore Richdmoore is offline
Default 05-30-2009, 07:15 AM
Since you want a new keyboard anyway, you may want to consider getting the US intl keyboard instead. This layout puts the keys back in a more normal position that the standard Dell 9 keyboard. A pinned thread is on the Dell 9 upgrade forum (the one above this one.)
Z4i Z4i is offline
Default 05-30-2009, 12:58 PM
For issues where keys fell off, Dell will send you a new keyboard. Intentional damage (e.g. taking them off) isn't covered by the warranty though. :P
I do prefer the US-International Keyboard. Personally on my own equipment I see parts failures as excuses to upgrade. :P
Unix fanatic
Vostro A90, 16GB SSD, 2GB DDR2, US-INTL Keyboard, FreeBSD 7.2-STABLE
Latitude E6400N, 2.4GHz, 4GB, 320GB, Opensolaris 2009.06 updated to build 118
Dell Tech Support agent
« A05 and battery times | Help?! »
