psyopper psyopper is offline
Default 08-25-2009, 02:55 AM
Updates generally do two things - provide security fixes and give feature updates (either to the OS or to your installed apps).
You really do want to install the updates. It's sort of like running WinXP right off the disc without doing any of the Windows Updates. It will work, but not as good as it can.
« Can't get SSD formatted from Mac back to NTFS | Video stability sucks on Win7 RTM 945 driver »
