| Junior Member Posts: 5 Join Date: Nov 2008 | How to install Windows 7 from USB Flash drive: Let me google that for you Install Windows 7 From USB On Aspire One - My Aspire One {dot} Com I don't know what kind of IT guy can't use the magic of Google, but that worked perfectly for me. Blue |
(#4)
| Senior Member Posts: 251 Join Date: Feb 2009 Location: Tucson Arizona | Patience. Loading any OS besides Linux on a 4GB machine is a chore. Loading OSX on s 16GB is not a 1 or two step procedure but it is not too rough. Stick with the DVD method and you should find that all will work out. Take your time. So many people have tried and failed before you only to find that it was a minor issue thay were missing. Good luck Runcore 64GB | 2GB RAM | ATP 16GB C6 SDHC | 1.3 Webcam | Bluetooth | OSX 10.5.6 | Fusion w/Windows XP | CrossOver | DellEFI 1.2A5 | BIOS A04 | 77Whr Battery Will install OSX for Food |
(#5)
(#6)
(#7)
(#8)
(#9)
| Junior Member Posts: 9 Join Date: May 2009 | I stand corrected . . . that's exactly what it was . . . NOW when I attempt to boot from Windows 7 DVD it works great, however I'm running into a new problem. It says it cannot install Windows 7 onto my disk because "the computer's hardware may not support booting from this disk. Ensure that the disk's controller is enabled in the machine's BIOS menu". I'll double check BIOS, but I'm pretty sure everything is set up correctly. New suggestions? |
(#10)
| Junior Member Posts: 9 Join Date: May 2009 | Ok, I had HD enabled, but the individual drive was disabled. Stupid . . . So I got Windows 7 installed and was going through drivers and whatnot. I upgraded the BIOS to A05 from A04 and in the middle it locked up. So now that mini is going back to Depot. ARGH!! The good news is, I took the HD and RAM out, swapped with my other mini so now I at least have a working mini with Windows 7 - just sucks that it doesn't have Bluetooth or a webcam. |
| Tags |
| installation help, mini, os x, windows 7 |
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-9-hardware-issues-problems/8076-help-i-want-whip-my-mini-9s-against-wall.html | ||||
| Install Windows 7 From USB On Aspire One – My Aspire One {dot} Com | This thread | Refback | 07-14-2009 02:17 PM | |
