dr_devious dr_devious is offline
Default Loose battery? - 04-23-2009, 08:49 PM
Any tricks to firm up a loose fitting battery?
ade099 ade099 is offline
Default Re: Loose battery? - 04-23-2009, 10:59 PM
you see where the groove is on the side of the mini where the battery slides in? just stick some tape there. worked like a charm for me.
« Charging Light Won't Come Up | Could not install XP with Dell DVD drive »
