eastmeon eastmeon is offline
Default re Help Pls - newbie's Mini9 w/Ubuntu is fubar :( - 04-17-2009, 09:27 PM
If anyone out there can help me & if so, eplain in dummy english what steps I need to take to fix this problem I would be so grateful - here's whats going on in a nutshell....
Just got my Mini9 less than a month ago, worked great - didn't use it for 1 wk, turned it on, said it had 186 updates available which started to come in and then the froze....and I get 2 messages - one says:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open() failed, please report.
THEN WHEN I CLICK ON CLOSE TO CLOSE THE ABOVE MSG OUT, another box opens up in the lower right corner that says:
Install Problem!
The configuration defaults for GNOME Power Manager have not been installed correctly. Please contact your computer administrator.
I am so sad that I can't use my mini - I tried calling Ubuntu US support, can't get through.
Can anyone help me please?
« Why SSD? | Power/charging leds: WEIRD!!! »
