I am having the strangest problem with the wireless on my Mini 9. When I first got it and using the Dell image, wireless worked on my WPA network like a champ. Then Update Manager indicated I should install 191 updates, and after that things went haywire. The network would not connect, then I tried a wide open (no security) access point, and it still wouldnt connect. I thought perhaps something went wrong with the install, so I am now running Jaunty 9.04 Netbook Remix (which I love by the way) on my new Runcore
SSD. I can get it to connect only if I have one network listed in the Network Settings at a time, and only if I let it fail the first time, cancel the connection, then click the network again in Network Manager. Seems to also fail If there is more than one network listed in the config. This driving me nuts for two solid days now.
Any ideas? I am using WRT-54GL routers with DD-WRT installed on both. I've also tried a standard ol Linksys router with no security at all, same issues.
Thx in advance
