riptologist riptologist is offline
Default Runcore SSD not being found. - 04-08-2009, 07:55 AM
I Recently bought a new 32gb runcore SSD for my mini 9. I decided to whip it clean and install win7 BUILD 7057. I had done this twice before with no problems but for some reason no matter what OS I try to install, it no longer detects my runcore drive. But if I plug the drive into a working computer via the USB cable it is detected by the Installed OS. I put the original 16gb Dell SSD in the mini 9 and any OS I load detects it but not the runcore. I have been trying to fix this for weeks but have gotten no where. Any help would be greatly appreciated.
mini 9 sees dell ssd but not runcore ( no matter what OS I try to use)
Runcore drive is detected by my other Laptop when plugged in via usb.
cloning software didnt work (although i think it was a bootloader problem so gunna try again)
LGSilva LGSilva is offline
LGSilva's Avatar
Default Re: Runcore SSD not being found. - 04-12-2009, 04:42 AM
you had the runcore working and it stopped or it have never been detected by your bios?
danish danish is offline
Default 05-17-2009, 10:29 AM
I'm having the same problem...
I had a perfect working dual boot with win7/OS X on my 32GB runcore, then tonight the screen just went blank and reset. From then on the Dell would not recognise the runcore.
I tried to boot off of USB, but when selecting HD 81 (the SSD) it simply did not detect and drive. I re-installed the standard 16GB STEC and it booted from USB with no problems.
I have now plugged the Runcore into my PC and it is detected.
When plugging the runcore into the Dell via USB it is detected.
I'm at my wits end as to what the problem could be...
somms somms is offline
somms's Avatar
Default 05-17-2009, 12:32 PM
If you can no longer select boot option '0' in order to run Dell Diagnostics tests for your SSD in order to confirm it has failed, you can create a bootable USB flash drive containing latest Dell Diagnostics here:
Did you purchase your SSD from MDD? If so, I suggest going to above link to request RMA.
« another ssd problem/windows xp | Won't boot :( »
