Reaver Reaver is offline
Default Card reader question/problem... - 03-30-2009, 09:36 PM
I'm having an issue with the built-in Card Reader on my Mini 9.
I have a 32GB card that my mini won't read. It see's it, but says it isn't formatted, and only gives me the option of 200MB as a format capacity.
I contacted support, and they say the card reader only supports 8GB cards. Wha? I see that people here are using 16s with no issue. What is the truth?
Is there anyone out there who has managed to get a 32GB to work? If so, how? Thanks in advance!
(and sorry about posting this in 2 different places!)
Sumanji Sumanji is offline
Sumanji's Avatar
Send a message via MSN to Sumanji
Default Re: Card reader question/problem... - 03-31-2009, 02:15 PM
Can you format it in another computer? (Although I imagine it is pre-formatted)
You could try and make a bootable Vista Recovery disk, then use the "diskpart" tool to format (or some other similar way). Just be careful not to format your SSD by accident!
Dell Inspiron Mini 9 Onyx
8GB STEC SSD ~ 16GB SD HC Card ~ 2GB PNY DDR2 ~ Intel WiFi Link 5100 ~ Bluetooth ~ 0.3MP Webcam ~ Windows 7 RC 7100 x32
« Mini keeps waking up from sleep, overheating in my backpack | PlugPlayManager error in Event Viewer »
