jp1216 jp1216 is offline
Unhappy External Bluetooth & Hotsync? - 10-31-2008, 02:51 PM
I'm trying to Hotsync my Palm Treo 755P with my Mini 9 via an external USB Bluetooth. I keep getting an error message saying that the COM port is already in use. I've tried creating other ports, but get the same error. Any ideas?
Mini 9 - Black - XP, 8GB, 2GB RAM, 0.3 Cam, 16GB SDHC, V220 Mouse...
Default Re: External Bluetooth & Hotsync? - 10-31-2008, 06:33 PM
Are you initiated from the desktop or from your palm? Try a soft reset if you have not.
If you happen to have ptunes I know that it can cause this problem. Deleting the usb file will fix this.
Hotsync software on the desktop should be set to local/usb, i think.
« keyboard | Screen brightness when AC plugged in »
