  (#31) Old
Founder
Dunhamzzz's Avatar
Default 06-26-2009, 04:47 PM
Great to see that we're getting closer to working out something.,
Tis a bummer that the unit has to go back to Dell in order to fix it...
Will they not fix mine tho as I have installed a Runcore drive and do not have the original anymore?
Edit what did u say to the support line? I can't get them to understand the issue!
  (#32) Old
Founder
Dunhamzzz's Avatar
Default 06-26-2009, 06:03 PM
  (#33) Old
Default 06-26-2009, 07:34 PM
crap i meant to put my post on as a new thread lol...
but i eventually found a thread more tailored to my problem. apparently a decent number of users have had their power adapters quick working or work intermittently. mine quit but today it happened to start working again so i have it charging the computer now but im still on the phone so i can get a replacement cause ya never know
  (#34) Old
Founder
Dunhamzzz's Avatar
Default 07-07-2009, 05:15 PM
After getting my Dell taken away from repair I received it back today.
They only replaced the motherboard and it is working fine.
  (#35) Old
Default 07-07-2009, 08:34 PM
Dang, is replacement the only option? The motherboard in mine was pulled from another machine.
  (#36) Old
Founder
Dunhamzzz's Avatar
Default 07-07-2009, 09:32 PM
Yeah I think so. Unless Dell release any further details on what the actual problem is.
  (#37) Old
Default 07-23-2009, 09:52 PM
so i read the topic twice but stil i don't get what is the solution? i have dell mini 9 with ubuntu and 04 bios.
  (#38) Old
Send a message via MSN to nollie
Default 09-17-2009, 08:05 AM
It would appear that I also have this problem.
Really hoping there is some sort of a solution as I have not had a good experience in the past with Dell Customer Services.
Dell Mini 9 - 64GB Runcore - 2GB RAM - Windows 7 - 16GB SD - Jolicloud Beta
  (#39) Old
Default 09-21-2009, 09:48 PM
I've been in contact with Dell over the last few days and it must be said they have been VERY helpful, clear and polite. A vast improvement over last year.
My Mini9 was scheduled to be picked up by courier tomorrow (luckily I was within a 2 week 'grace period' at the end of my warranty) though I missed a call this evening with a voicemail left informing me a new battery and power adapter will be sent out instead (need to confirm my details first).
To be honest I doubt it will fix this problem, though we shall see.
  (#40) Old
Qagak's Avatar
Default 09-28-2009, 07:55 PM
Well, it's finally happened (& this is my 2nd Mini). If the 3rd Mini fails, I don't believe I'll be getting another one & I might also be done with Dell.
My Sony laptop + desktop & Dell 600M, while slow by today's standards + hot like an m f-er, have yet to fail me in ways the Mini has . ~knock on wood~ Oh man, am I'm disappointed....
I'm glad I didn't do any upgrades yet & that this was at the top of the forum.
Edit: I've seriously tested my Mini for about 9 hrs now, & I believe that the OEM AC adapter went bad/shorted out somehow. It is running from the outlet/surge protector currently with a different adapter. The 1st one I used was OEM + the other was non-OEM. I will continue to monitor the computer. I wonder if that's what killed the 1st Mini (because it worked so perfectly that I can't believe it was a lemon or that I have such bad luck)....
I'm glad it seems to be turning out to be a false alarm ('cause I was about to wonder how 2 Minis would fail in the same way in such a short time)....
Edit#2: About the AC adapter/charger that failed, I noticed that it's different to the OEM one that I have now. The picture quality is not exactly what I would like (when you zoom in), but the prongs should be clear enough. The 1 on the left is the one that failed.
battery, charging, mini 9
« Bluetooth module not recognised after clean XP reinstall | New ssd windows 7 install help »
