wanga1983 wanga1983 is offline
Default Re: SSD Corrupting - 04-21-2009, 10:43 AM
Originally Posted by frustrated2009
My SSD was fine other than typical lag for 5 months and then this week all hell broke loose. First BSOD and then after a reinstall of xp a black screen 'operating system not found' error at boot up.
I ran the diagnostics before I reinstalled and everything passed other than it found some bad sectors.
If something happens once it may be a bad file but if it keeps happening it appears to be the disk itself,as I found out.
Dell should just ship every mini with 2 SSD's lol. To their credit it seems like they are very good about swapping out bad with good. My new SSD will hopefully be here by weeks end.
I have a similar problem. Dell is replacing the SSD.
TobyRhino TobyRhino is offline
TobyRhino's Avatar
Default 08-06-2009, 06:45 AM
Mmm... similar thing happened to me. Windows froze and refused to boot. Windows install disks refused to boot.
managed to boot some linux distros and installed moblin - that too refused to boot after installing.
Ran gparted, testdisk, and finally Dell's diagnostics program - definitely a hardware problem.
Sent an email to Dell and they are preparing to send me a new SSD. Hope the new one doesn't go belly up too. Although the whole process so far with Dell has been good.
« Wifi/BT shortcut doesn't work in Windows 7 | Runcore 32 gb ssd heat issues »
