bundee1 bundee1 is offline
Default Heat issue solved? - 03-24-2009, 03:00 AM
A coworker just got a brand new Mini 9 with the stock 1GB ram and a 16gb HD. He has windows xp installed and I told him to install coretemp. Mine is a refurb Mini 9 with G.Skill 2gb ram and a 16gb HD. Both of us started our machines at the same time. After booting up completely his computer's idle temperature was 10c lower than mine. His idle temp was 25c (with coretemp beta .95 which has a tjmax of 90c and 0 offset) mine was 35c.
Anyone one else want to post their configurations and coretemp temps?
Jollydet Jollydet is offline
Jollydet's Avatar
Send a message via MSN to Jollydet
Default Re: Heat issue solved? - 03-24-2009, 09:09 AM
67c after running for 2 hours just idleing, max temps seen are over 90c . with coretemp
setup is 16gb stec, 2gb ram upgrade, windows 7, similier temps when running windows xp
jaredpace jaredpace is offline
Default Re: Heat issue solved? - 03-24-2009, 10:47 PM
8gb winxp
coretemp shows 125c tjmax and temps max around 93 to 98c
idles in the 60s
1.6 Ghz Intel Atom w/ HT
125C tjmax
2 GB crucial DDR2 4-4-4-10
8GB Intel SSD serving Win XP +
16GB Topram Class6 SDHC
9" LCD
1.3 Webcam
Intel 5100 802.11abgn
BT optical laser mouse
BT fabric Keyboard
Missing apostrophe key
Arturhash Arturhash is offline
Default Re: Heat issue solved? - 04-15-2009, 09:52 AM
Hot stufff!!
Mine also heats up a bit too much.
I would like someone that has any ideas on how to cool the animal, that posted them here.
Thanks and regards
Artur Rosado
raven raven is offline
Default Re: Heat issue solved? - 04-15-2009, 08:01 PM
usb fan? lmao.. thats what i did. i use my mini 9 for dj and parties.
lolz. people are amazed i dont use a mac. my response is. do you want to listen to country music? LOL
« Strange Standby/Hybernate behaviour - can anyone help? | Airport: Not Configured »
