Default Re: Post your CPU temps here? (using Core Temp) - 04-29-2009, 07:59 PM
The CPU temp should not get that hot. What probably happened is that the thermal pad between the palmrest metal panel and the CPU is not firmly attached.
chado chado is offline
Default Re: Post your CPU temps here? (using Core Temp) - 04-29-2009, 08:34 PM
I didn't recognize anything but the high temperature. Maybe it was a bad idea to run BOINC on a computer without a fan. ( :? Hindsight is always easier than foresight - MINI9 has no "rescue-fan" or "emergency-shutdown" when a critical temp is reached.
Maybe you're right and there was something wrong with the thermal pad. Otherwise the MINI9 was made for burn-out.
The idling temp was round about 67°c (<20°c ambient temp)
MINI9, N270, 1 GB RAM, 16 GB SSD
********CURRENTLY DEAD********
« Sound Problems. | Consistent Wireless Problems (different from others!) »
