ILL ILL is offline
Default Power light keeps flashing - 03-16-2009, 11:36 PM
My mini seems to be functioning just fine, but it is currently plugged in and the power light keeps flashing. Does anyone know what this means? It's driving me crazy - all that flashing...
Cruleworld Cruleworld is offline
Cruleworld's Avatar
Send a message via AIM to Cruleworld Send a message via MSN to Cruleworld
Default Re: Power light keeps flashing - 03-17-2009, 04:27 AM
Mine flashes when it is in sleep mode, my guess is you have your lid shut and the computer is asleep.
drpepper1720 drpepper1720 is offline
Default Re: Power light keeps flashing - 03-17-2009, 05:55 AM
This happened to me just the other day, at least something similar. Are both the lights alternating and flashing, both orange and white? If they are, make sure your AC adapter is plugged in correctly. Like, make sure it's pushed into it's port on the computer all the way, and try plugging it in and unplugging it a couple times. This fixed it for me, hopefully it helps as I know what you mean. The flashing was ridiculously annoying.
Mini 9 -- 16GB/1GB/OS X
« So I've noticed alot of wifi problems... | Ubuntu FN 9 screen brightness not working »
