Mongo Mongo is offline
Default Issues with sound after upgrade to BIOS A03 - 03-16-2009, 08:14 PM
I received my new Dell Mini on Friday night and was ecstatic to begin playing with it. I then realized that the battery was not charging. I was able to fix the battery following the advice from Somms regarding FN+B ( and by upgrading to BIOS A03
Once running all this, I was able to get the battery to charge without issue. The problem now is that my sound card does not seem to work. I've searched the forums but can't seem to find anyone with a similar issue. Can anyone help me with this?
Elcuolo Elcuolo is offline
Default Re: Issues with sound after upgrade to BIOS A03 - 03-19-2009, 12:10 PM
I think that the latest BIOS is A04 why don't you try upgrading to that to see if it fixes your problem? ... 10_A04.exe
Fingers crossed on your behalf.
cookiemonster's Avatar
Default Re: Issues with sound after upgrade to BIOS A03 - 03-20-2009, 10:14 AM
What operating system are you using?
« Squeaky keys | AC Power not working/Charging issue »
