cj86 cj86 is offline
Default 12-02-2009, 04:46 PM
Mine is exactly the same, however it was fine running on xp. I'd just installed sl. Sounds just like a ticking clock.
hiddi hiddi is offline
Default 01-23-2010, 01:31 AM
anyone figure out a solution? im out of warranty and if it's something i can fix at home i'd like to. i can turn off the sound and not hear the noise but with the sound on or headphones get the almost clock tick tock noise others are.
« Yet another battery issue | Booting Problem »
