startvlr startvlr is offline
Default crap magnet! - 03-14-2009, 09:36 PM
MANNN!!!! I am such a crap magnet.. Ok..can anyone anwser this question. Received my Dell Mini 9.. Windows update put microsoft framework 3.5 on..Took forever to download and accept..Now there is a yellow "download" character in the system tray that is always there. When I click on to download, it does it's thing and finishes then comes back WHAT THE HECK????? Ignorance I am sure on my part, but I am trying to lean..Can anyone help...
bunjin bunjin is offline
bunjin's Avatar
Default Re: crap magnet! - 03-15-2009, 03:21 AM
Go to Control Panel>Security Center>Autmatic Updates. You will see it is enable. Click button and disable.
I'm not sure how "lean" this will make you if any.
Retired Mini user
WolfKeeper's Avatar
Default Re: crap magnet! - 03-15-2009, 04:35 AM
Some times it takes a couple of reboots to get through everything it needs to install.
Getting an iPad
« What is too hot??? Plz help!! | Wireless won't work with my specific network! »
