| Junior Member Posts: 15 Join Date: Sep 2008 Location: Boston | Check the Aircraft Manager control panel. Try enabling and re-disabling Aircraft Mode. Looking at the code it seems this manages charging as well as turning the radios on/off. http://dell-mini.archive.canonical.com/ ... t11.tar.gz is the source for this package. |
(#4)
(#5)
| Junior Member Posts: 2 Join Date: Nov 2008 | Can someone explain in detail exactly how to fix this problem? I downloaded and extracted the file listed above but I have no clue what to do after that. Is this stuff uncompiled? I'm not really familiar with compiling stuff in Linux. What are the terminal commands to get this Aircraft Manager up and running? Also, what is the exact URL for the Dell repository? I put http://dell-mini.archive.canonical.com in Synaptic and it seems to have not added it. My battery is totally drained now and I'm not sure how to recover from it. I tried booting from my Backtrack 3 live USB, hoping it would charge under that, but it didn't help. |
(#6)
(#7)
(#8)
(#9)
| Junior Member Posts: 3 Join Date: Nov 2008 | Thanks God I found this forum! Very happy with my mini9 (ubuntu) until i decided to use airplane mode to save battery. Then the battery refused to charge! Last thing I would check would be the status of airplane mode! on reading this thread, i rechecked, and alas, even using the wifi, airplane mode was checked! un checked it, and now battery seems to be charging again! Thanks to you, forum contributors! |
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-9-hardware-issues-problems/420-battery-not-charging.html | ||||
| Ubuntu?????????? | Post #0 | Refback | 08-21-2009 04:46 AM | |
| Una histeria muy personal Blog Archive La batería del Dell Mini 9 no se carga | This thread | Pingback | 06-09-2009 09:47 PM | |
