  (#71) Old
Default where can I download the .deb package? - 07-09-2009, 06:37 AM
Originally Posted by Noble713 View Post
I managed to download the actual .deb package, get it installed, and low and behold this fix works.
Where can I get the .deb package?
  (#72) Old
Default 10-06-2009, 05:47 AM
Thanks so much for posting this! When my new Mini stopped charging I contacted Dell tech support, who sent me a new battery and power supply. Neither worked. After finding this post and disabling airplane mode (I'd just been on a trip and enabled airplane mode on a flight), everything worked fine
I wouldn't call this a bug, but it should be in the user documentation and in the tech support knowledge base. I plan to call Dell back on this one and (hopefully) improve this.
  (#73) Old
Default 10-10-2009, 05:26 PM
Battery went out as well on A04 short-long-short beep system... Dell customer service was top notch as always and will send a replacement.
The Dell Mini was left 3-4 days without any juice in its battery and probably that's what caused it. What's revolting is the fact that other lithium batteries (laptops, cellphones or pda's) were left until reaching 0% and charged everytime without a glitch. Is there something wrong with these Dell batteries or a warning should be posted 'don't let your Dell Mini's battery reach 0%'..?
  (#74) Old
Default batt. won't charge - 10-10-2009, 08:07 PM
so please can anybody tell me how to turn on and off my airplane mode.. So I can see if I can get my batt. to start charging....
---------- Post added at 12:07 PM ---------- Previous post was at 12:05 PM ----------
maybe you could tell me how to turn on and off the airplane mode..PLEASE
  (#75) Old
Default 10-12-2009, 08:57 AM
if the battery could not be working reasonablly, you can go to have a change.
focus on the battery development.
http://www.batterystyle.com
  (#76) Old
Send a message via MSN to anjilslaire Send a message via Yahoo to anjilslaire
Default 12-20-2009, 04:39 PM
OK,
Ironically, I now experience the battery failing to charge behavior. Ironic because I've run it on previous UNR versions without issue, and have always been able to restore battery charging by disabling airplane mode.
I'm running Karmic UNR, installed the latest Aircraft-manager 12.1 deb from the PPA
https://launchpad.net/~opensource-su..._filter=karmic
Flipped it on, flipped it off, now the battery refuses to charge, and has drained to 0%, so I'm stuck on AC power now. I've tried the following:
http://www.mydellmini.com/forum/dell...html#post12070
http://www.mydellmini.com/forum/dell...html#post15644
Also, I have repeatedly disabling Airplane mode, even booting into a live Jaunty environment, installing aircraft-manager into Jaunty & disabling it, suspecting it having been a compatibility issue with Karmic.
My warranty has just expired, so sending off for a new battery is not a trivial matter. Also, this literally just happened after adding aircraft-manager to Karmic, so I'm pretty sure its not a bad battery.
Help? Thanks.
Mini 9 Red|2 gigs ram|32gig SSD|Intel 3945 a/b/g|Ubuntu 10.10 UNE
Need more useless stuff to read on teh internetz?
http://anjilslaire.wordpress.com/
  (#77) Old
Default 12-27-2009, 03:33 AM
if you have not used your mini in a while the battery may be to depleated to start the charging process. if your unit works fine on AC but won't charge at all and stays at 0% then check the battery by single clicking. if the battery status is less than 0.5 wh then the battery is too depleated to start charging.
turn off the unit and unconnect the cord from the unit. quickly reconnect the cord to the unit for a second until the power light comes on and then disconnect again. do this several times (at least ten) then turn the unit back on and recheck the battery status. once you get over 0.7wh the battery will have enough juice to start charging again.
  (#78) Old
Default Thanks, mydellmini, and dougma - 01-08-2010, 03:43 AM
Originally Posted by dougma View Post
Check the Aircraft Manager control panel. Try enabling and re-disabling Aircraft Mode. Looking at the code it seems this manages charging as well as turning the radios on/off...
Joined just to make this post: Thank you!
I got the "battery won't charge" disease and after an hour of 'dell hell' trying to get support, decided to do some research (which I should have done FIRST).
Sure enough, it was Aircraft Mode - I had used it to disable BlueTooth thinking 'waste of battery'.
Thanks to the forum and specifically, dougma, the battery now charges.
  (#79) Old
Default 01-16-2010, 03:05 AM
Similar problem to those mentioned here, but mine is running XP. Prior to a few months ago I had the Ubuntu loaded on it. My corp laptop bit the dust and I rebuilt the Mini with XP SP3 so I could use it for corp email and such until I got a replacement. The dreaded battery issues started soon after. Until than my Mini had spent most of it's life on the shelf. I was traveling a lot and did not feel like dragging a corp laptop and the Mini along.
I went so far as to send it back to Dell. They supposedly tested it and say it is fine, but refuse to give me a new battery. They state the battery is more than a year old, which is true, but I argue it has not been USED for a year. No hope now I guess except to buy another battery.
  (#80) Old
Send a message via Yahoo to coteanualex Send a message via Skype™ to coteanualex
Default 11-28-2010, 06:32 PM
The battery cannot be identified.
The system will be unable to charge this battery.
That's an error on startup , and the power and battery flash like xmas tree!
Can any1 help me ? pls ! P.M me pls
Dell Mini 9
---------- Post added at 06:32 PM ---------- Previous post was at 04:44 PM ----------
Hey , guys , i have a solution!!! On your desktop , plug in your AC and pull out the battery , wait a few sec. and plug the battery in . Now , your battery should charge , do this evry time you want to charge it.
« Battery won't charge with A00/A03/A04/A05 | SPI Bios chip »
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-9-hardware-issues-problems/420-battery-not-charging.html
Posted By For Type Date
Ubuntu?????????? Post #0 Refback 08-21-2009 05:46 AM
Una histeria muy personal » Blog Archive » La batería del Dell Mini 9 no se carga This thread Pingback 06-09-2009 10:47 PM
