thacrownprince thacrownprince is offline
Default RunCore 32 GB USB Port Broke Off - 02-23-2009, 10:59 PM
Hey Everyone,
I recently just got the RunCore 32 GB SSD. I installed it and everything works great. However, when I tried to use the USB Cable to clone the RunCore SSD, the port just broke off. Is it that flimsy or did I get a faulty one that they did not weld on properly? I have it up and running as I am typing this. I was wondering if you guys had this problem or if it is even worth trying to get it replace. Everything works, minus the USB port falling off. I just installed everything manually. Is there a solution to cloning the SSD without using the USB port on the RunCore? Thanks for your help.
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: RunCore 32 GB USB Port Broke Off - 02-23-2009, 11:27 PM
Well that's unfortunate. If you don't plan on using that port in the future, then keeping it as is should be okay...on the other hand, I myself would ask MDD for a replacement, just for peace of mind (in case you do want to use the port in the future). The port is mainly for convenience...take the SSD out of the box, connect it using the microUSB cable to your mini, then copying the OS over (via TrueImage etc) in one go. Same thing can be done, with more steps, using an external drive.
« dead SSD | Mini going into standby mode after resuming from hibernation »
