minionthebus minionthebus is offline
Default 10 seconds freezes after replacing SSD - 01-30-2009, 07:48 PM
My SSD died and Dell sent in a replacement. I know it's a different kind because it doesn't look the same at all. The new one has a heatsink so it gave me hope that it would be better than the previous one.
Ever since I installed it, I've been experiencing random and semi-frequent periods where everything becomes unresponsive for about 10-15 seconds. I've diagnosed it as the SSD or SSD interface by looking at dmesg:
Jan 19 18:12:22 hostname kernel: [ 219.806299] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x2 frozen
Jan 19 18:12:22 hostname kernel: [ 219.806341] ata1.00: cmd ca/00:08:63:fe:c3/00:00:00:00:00/e0 tag 0 dma 4096 out
Jan 19 18:12:22 hostname kernel: [ 219.806350] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Jan 19 18:12:22 hostname kernel: [ 219.806364] ata1.00: status: { DRDY }
Jan 19 18:12:27 hostname kernel: [ 224.840541] ata1: port is slow to respond, please be patient (Status 0xd0)
Jan 19 18:12:32 hostname kernel: [ 229.819816] ata1: device not ready (errno=-16), forcing hardreset
Jan 19 18:12:32 hostname kernel: [ 229.819838] ata1: soft resetting link
Jan 19 18:12:32 hostname kernel: [ 229.992244] ata1.00: configured for UDMA/100
Jan 19 18:12:32 hostname kernel: [ 229.992284] ata1: EH complete
Jan 19 18:12:32 hostname kernel: [ 229.993602] sd 0:0:0:0: [sda] 15005088 512-byte hardware sectors (7683 MB)
Jan 19 18:12:32 hostname kernel: [ 229.993690] sd 0:0:0:0: [sda] Write Protect is off
Jan 19 18:12:32 hostname kernel: [ 229.993815] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
I ran the Dell diagnostics a few times and nothing seems to be out of the ordinary with the SSD itself. Could it be software incompatibilities? I searched on the web and it seems that this is fairly rare but I found a few other cases where this happened with other hardware, the fix almost always was a newer kernel.
I am using Ubuntu UMPC (8.10) and the Dell Ubuntu (8.04) and error happens with both.
I am a bit scared to call Dell again. I wasted a lot of time last time I called them trying to explain that I had Ubuntu and that the windows screen never came up and that I had no F12 available on my keyboard. I guess I will eventually get annoyed enough to call them
Thank you!
Default Re: 10 seconds freezes after replacing SSD - 02-01-2009, 09:14 AM
Call Dell back, demand a whole new machine. That's unacceptable.
« Drink spiled on keyboard now not working | SD Card not being recognized... »
