KwisatzHaderach KwisatzHaderach is offline
Default Re: system freezing after bios A04 update - 02-02-2009, 07:02 AM
Mine froze also until I hit load defaults in the bios. If you have done that, and tried everything else, then yes go ahead and flash. In either case, it needs to go back to Dell. A system freezing is totally unacceptable. At that point I would flash it too.
MSI P45 Platinum
Intel Q6600 @ 3.6ghz
Thermalright 120 Extreme
Accelero S1V2
Creative X-Fi Xtreme Gamer
4GB Crucial DDR2 800
Antec Nine Hundred
Vista 64 Ultimate
LG Flatron W2452T
Dell Mini 9 16gb SSD 1GB memory 1.3mp Web Cam
cookiemonster's Avatar
Default Re: system freezing after bios A04 update - 02-02-2009, 07:14 AM
Since you seem willing to take that chance, I say go for it. First reload default values in the BIOS, as suggested previously, & if that doesn't fix it then re-flash the BIOS. If you brick your machine, at least you know it'll get fixed.
forceps forceps is offline
Default Re: system freezing after bios A04 update - 02-23-2009, 10:06 AM
Just as an update, the system has been quite stable since I just reset bios values to their default state. I forgot to do that initially. Thanks for the suggestion.
« Network problem | dead SSD »
