jamal_bao jamal_bao is offline
Default card reader problem after win xp reinstall - 07-31-2014, 10:05 AM
Hi , after a first fresh windows xp reinstall my card reader appears in device manager as unknown device. my system detects it but after the jmicron driver install nothing happened. if i uninstall the driver the usb remove device icon appears on my status bar and if i click on it i see sd card reader icon.
anyone have this problem . please help me with this one
Default 08-06-2014, 06:04 AM
any suggestions ? the card reader was working before this reinstall.
lswartz lswartz is offline
Default 08-06-2014, 09:52 PM
Have you considered using a new OS?
Default 08-07-2014, 08:00 AM
thanks i will try to install a new os and see if it is going to work.
Default 08-07-2014, 02:25 PM
My suggestion was also to get you to a newer OS which is supported. I like several versions of Linux; Ubuntu, Mint & am currently using Lite Linux on a Mini 10v. They are all easy to tryout before installing. Almost all OS's have outgrowen my 4 GB SSD on my Mini 9.
If you really need Windows then I like Win 7.
Default 08-07-2014, 08:57 PM
the problem is solved now. i do not know how but when i was going to install a fresh copy of windows i got a message for usb mass storage and the sd icon is now present. i did a few restarts and used different memory cards it is all ok.
my dell is working great , the sd problem was the only issue. i use it only for diagnose ,only vcds and revo software installed.
thanks for sugestions
Default 08-08-2014, 04:37 PM
I'm glad you got it working.
« Replacement Battery not accepted/No charging | URGENT Help Required Please !! - Dead Mini 9 »
