atgw atgw is offline
Default dell mini 9 broadcom 802 not connected - 01-01-2014, 02:06 PM
Hi All & Happy New Year
my 9 is ok on the lan but in spite of uninstalling the 802 & reboot it wont show any networks & after no good repair it cannot connect
? any ideas other than get a wireless dongle
system xp sp 3 2 gb ram 16gb ssd both new bits
Default 01-01-2014, 02:45 PM
Isn't the Broadcom 802 the Bluetooth module? What does Windows say you have for network adapters?
Default 01-01-2014, 03:47 PM
Hi just its a bcom 802.11g network adaptor - sys manager says its working OK mmm...looks to me like a driver prob but I wont pay $40 usd for a new driver & win says cant connect
Had a nightmare with dell updates to my w7 insp 5040 = first 24 hrs the new webcam driver update crashed w7 & had to do a full sys restore
as usual its so much easier to work around a win prob than solve it
But like all viewers I like my mini 9 esp when its working as it was out of the box.
Default 01-01-2014, 11:50 PM
Is this the network card that came with the Mini 9? You can get the driver for free from Dell - Drivers & Downloads | Dell US Probably a good idea to let it do the analysis to see what you need. Who says you need to pay $40 for a driver?
Wink 01-02-2014, 10:13 AM
yes all original - googled link for broadcom drivers & free - then when its download time $40 of the best
Many thanks - as always - for your helpful hints - I may just try the dell w xp cd's & my ext dvd drive to get the original driver re installed the US of A is so far away from N Devon UK
Default 01-02-2014, 05:38 PM
took your good advice & Dell detect is running complete check - will post details when complete. = warm glow to own a legacy dell that still gets 100% solid support.
too far to go upstairs to get the dell cd's....real lazy after the long break....
Default 01-02-2014, 07:42 PM
passed the complete test still the same fault & also downloaded the 802 driver updates = maybe its a duff card
dont think so as it says wireless connection 3 not connected firewalled
? connections 1 &2 status? lost
Default 01-03-2014, 01:14 PM
is the card easy to replace? - going to try a wi fi dong now
tried o2 web dongle loaded but no signal = ? lid Ae gone bad OK will try a tp link wi fi Ae in its usb slot
Smile Yes wi fi thanks to TP Link aerial & O2 dongle - 01-03-2014, 04:02 PM
O2 dongle loaded OK but would not detect any signal = removed
TP Link aerial found a signal (my house wi fi) but needed Window advanced settings to use windows to config.
Result thanks to TP Link Ae the tiny Dell is on line.
Very strange the internal dell lid ae dosent detect a signal - TP Link Ae says my house link is weak and yet this dell insp 5040 w7 says its strong?
Still think its a driver problem & its silly for the dell sys test to report all is working when it dosent do a functional test on say lan or wi fi....
but golden rule = leave well alone
Default 01-04-2014, 02:08 AM
Probably not a driver issue, in my opinion. The WiFi card is trivial to replace as long as you are careful with the antenna connections, which are fragile. But I had issues with the Dell card not seeing my router, which prompted me to replace it with an Intel 5300 (note that this one has three antenna connections - I added a third. You probably want a card with two connections.)
« Dell mini 9 reboot loop | STEC 8GB SSD 0MB in BIOS »
