megaTROLLforever megaTROLLforever is offline
Default KingSpec 64gb problem error format - 12-24-2013, 07:04 AM
I gave a detailed description of the problem.
Initially, I installed Windows7 on netbook DELL 910. I used Windows7, everything worked fine. But recently Windows7 freeze when I startup netbook.
After rebooting the netbook, Windows not boot.
Installed SSD drive(KingSpec 64G Mini PCIE MLC SSD Card IDE PATA) in a netbook DELL 910.
Turn netbook DELL 910 displayed error (operating system will not boot).
Trying to install from flash usb Windows7. SSD drive shows 0mb space, then trying to format the SSD drive (there is an error). In BIOS shows full size 63317Mb. Bios version A07.
I tried to format the SSD drive in other programs, but did not work format. Disk size was 0mb. A should be 64GB.
I would be grateful if we can find a solution to this problem.
---------- Post added at 10:04 AM ---------- Previous post was at 09:57 AM ----------
I have a "STEC 4GB SSD Solid State Drive R832H mini pcie pata". This SSD works fine with my netbook Dell 910. I rechecked.
Default 12-26-2013, 07:27 AM
Council found, insert SSD other netbook Dellmini9 and maybe SSD will work. But i do not have second Dell mini9. Maybe someone knows what netbook(or laptop, or motherboard PC) support SSD mini pcie PATA?
Default 12-27-2013, 02:23 AM
Default 01-07-2014, 06:27 PM
After reading the forum. I have understood that this is a problem with the controller. All problems disappear after controller firmware. But KingSpes not give support to customers. On the board minipcie written that controller from SMI(Siliconmotion) SM2236.
But sadly the software for this controller is not present. I downloaded the software for SM2235. But it does not work on SM2236.
Someone helped support from KingSpes?
jamal_bao jamal_bao is offline
Default 08-06-2014, 06:10 AM
try google "sm2236 controller firmware usbdev.ru"
Default 10-16-2014, 07:28 PM
Tried it, no result. While there is no firmware for the controller SM2236.
« Battery not recognized, flashing orange light | Dell Mini 9 keyboard problem »
