cygnus cygnus is offline
Default Potential reason for all the Mini 9 sleep issues - 09-18-2012, 04:10 PM
If you follow this thread, it goes through the symptoms plus the reason/solution. Essentially, it's the motherboard. Some are good, some are bad. For the record, everything was set exactly the same way for both motherboards (BIOS settings, OS settings).
I hope this helps everyone with the same unsolvable issue. It may not be the best solution, but at least it's something.
onetrueboo onetrueboo is offline
Default 10-09-2012, 05:41 PM
The solution requires a new motherboard?! You've got to be kidding me. That's no solution nor explanation.
I've had my mini9 since early 2009 - close to 4 years now. Recently it developed the same problem - will not wake from sleep/standby. Sheesh. And, I'm running WinXP - what it came installed with - not OSX nor Linux.
It's a pity as I believe the mini9 remains one of the most desirable wee little computers to this day. Unlike a tablet it includes a usable (just) keyboard and mouse, THREE usb ports, SD card slot and a small but brilliant display (iPad includes no USB nor SD card slot - hobbled). The OS isn't crippled as it is with some tablets.
Wonder if this is one of those planned obsolescence things, as mine failed for no reason. I didn't do anything unusual.
mini 9, motherboard, sleep
« sleep/standy - will not wake (!) | Mini 9 making me pull my hair out! »
