Orik Orik is offline
Default Keyboard Ribbon Tab Missing; What to do? - 07-12-2012, 05:19 AM
Hello! I recently ordered a lot of replacement parts and got my old Dell Mini 9 booting and working. However I noticed that the Keyboard function was off. The reason being that I was missing a keyboard tab.
I tried using other things, tape, plastic, etc. to get the ribbon to stay in place but none of it seemed to work.
Where can I get a replacement for this tab, or what sort of DIY-hacks can I do to secure the keyboard cable?
Default 07-13-2012, 06:03 PM
If I understand your reference to "tab" correctly, it's the slide-lock mechanism that holds the ribbon in place. I think this works by clamping the ribbon down onto the contacts, so you might try sliding a piece of thin cardboard between the top of the ribbon and the connector to wedge it in.
clip, keyboard, mini, ribbon, tab
« REAL Resolution Fix | No sound through speaker on Dell Inspiron 910 running a clean install of Ubuntu 12.04 »
