Default Issue with a Dell Mini 9 - 05-31-2012, 08:50 PM
Not sure if this issue has been posted about before but I have a dell mini inspiron 910 that is a little low on space but boots up to Windows XP fine.
The problem is when you click on any programs. Take Paint for example, when clicking on Paint it usually is supposed to open up perfectly fine how I get the "Open With" box pop up.
This happens on whatever program you click on. I was wondering if anyone else has had this issue before and if so what did you use to correct the error?
Any help would be amazing!
Thanks!
Default 06-12-2012, 09:33 PM
· Hi TheR2point0,
If it gives “open with “ message on any application then download the dougknox registry fix for file association from the below link .
http://www.dougknox.com/xp/fileassoc/xp_exe_fix.zip
Regards
Krishna Chaitanya
Dell | Social Media Outreach | Global Social Media & Community
« SSD shows 7683MB in bios but... | Bottom of screen missing »
