I have a Mini9 Bios version A07. I bought a new
SSD from Newegg just to upgrade from a 8GB to 30GB. Item#:
N82E16820227749
OCZ Strata Series STR-MSATA-30G mSATA 30GB SATA II MLC Internal Solid State Drive (SSD)
When I installed the new drive I do not get a Bios screen. The power light comes on for a few seconds and nothing. Now before you say it is a dead drive I installed it on my PC with a
SSD slot (Gigabyte MB Z68xp-ud3) and was able to partition / format and copy files to and from. The only thing I did not test is if my PC will boot from it. The old drive still works and tested in my PC as well. Any Ideas?
