(#11)
(#12)
(#13)
(#14)
(#15)
| Junior Member Posts: 11 Join Date: Feb 2012 Location: Virginia | lswartz is on point with his response. After working with Linux for many years, when your HDD goes read only you have issues. Best thing to do is check it with something like gparted to verify the drive is not being flagged for failure. Or if you already have Linux installed you can fsck to make sure the file system is intact. I hope this information helps, and would like to know the outcome of your problem. Change DHCP tab setting to fit your needs. Check TFTP tab shows "Bind TFTP" as your deployment computer IP. 0MB SSD BIOS fix for Mini 9 Notebooks Works for 8GB STEC and Higher SSDs |
(#16)
(#17)
(#18)
(#19)
(#20)
« black screen in my dell mini 9 but work fine when Connecting to other screen
SSD 32GB Problem. H E L P »
