(#11)
(#12)
(#13)
| Junior Member Posts: 11 Join Date: Feb 2012 Location: Virginia | Yeah the update I did was for a 8GB and will not work for 4GB but from what I read should with 8GB and higher. Hey, keep us posted, I would like to see the outcome. I have lost hair over this issue. Thanks, ---------- Post added at 08:33 PM ---------- Previous post was at 08:15 PM ---------- Also if it helps, I have a TFTPD32 server setup on my main computer on the network to push Ubuntu 11.10 You may/will have to update the DHCP ips to suite your network but everything you need to PXE boot is provided. Extract the zip to your c:\ assuming you are running windows. It should create a tftp folder. You will see a tftpd32.exe app. Run it. Once in the app click the settings button at the bottom. Then click DHCP tab and update the "IP pool starting address" and the default router IP. Then go back to TFTP tab and make sure the "Bind TFTP to this address" is updated with your computers IP address you are running TFTPD from. tftp.zip Hope this helps! |
(#14)
(#15)
| Member Posts: 41 Join Date: Dec 2011 | Did not work for me. It identified my SSD as a Runcore and returned the message that it "could not initialize this disk." But did give me the firmware I have. Bummer. But thanks for your help...I'm certain this would have worked if i had a STEC ssd. This is going to help a lot of people with STEC drives. But I'm encouraged that firmware flashing may help. I'm going to seek help from Runcore. The firmware I have is 1571 (or close) there are two upgrades since then. I learned some can go straight to the higher, others have to take it in two steps. All, I googled "dos on a stick" and got CNET download link for DOS-On-USB. It's great... and free. It puts a bootable DOS71 on a 128mb usb stick and only used 17mb. Works great on the mini 9. Here's the link: DOS-on-USB - Download.com (use the direct download choice) |
