mjgreenwood mjgreenwood is offline
Default SSD hardware differences - 11-17-2011, 06:51 PM
So I have a mini 9, we've had it for a while. I've installed ubuntu on it a number of times.
I went to install the latest version 11.10 and noticed that the drive is to small.
I have the 4gb ssd.
So I ebayed a 8gb drive for 20 and it doesn't work.
I've read some cryptic threads that state that mini pci-e ssds are not all the same. some only work with specific netbooks.
I've been in hardware for a while. It would seem to me a ssd drive should be no different than another ssd drive. So my question is are they different and what specific models are known to work with the mini9.
I read in one thread kingspec didn't work and in another that it did. So I'd love to see a reference.
Default 11-18-2011, 01:28 AM
It's not that Kingspec doesn't work, but the performance is poor.
The specs you need are PATA (not SATA), 50mm (not 70), MiniPCIe. If the description does not say it is for the Mini 9, then it isn't.
darrencax darrencax is offline
Default 12-10-2011, 01:13 AM
I got a 16GB Kingspec in the Mini I just resurrected. Benched the reads at 60MB/s and writes at 20MB/s. So, performance isn't seller but it gets the job done. I'm running mine using Windows 7 (VERY trimmed down), no paging, and no system restore and it's doing quite well. I feel more limited by the CPU than the SSD.
« FN + 2 (WIFI BUTTON) Not working....... | new xp install with new 64GB AMP SSD »
