Default Bluetooth module not recognised after clean XP reinstall - 09-18-2011, 02:42 PM
Dear all
Strange thing happened recently, after a clean install of XP on my mini 9, my bluetooth module is no longer recognised. There is nothing in system properties, even though bluetooth is enabled in the BIOS (A05)
Is it just coincidence that the module broke at the same time I chose to reinstall? I guess its possible it broke prior to this, but I just didnt notice
Just wondering if this happened to anyone else, or if there is something I should be aware of?
Many thanks
Scott
Default 09-18-2011, 08:57 PM
have you re-loaded the radio switch utility from your Dell Applications?...that is needed for Bluetooth
Default 09-21-2011, 02:38 PM
Thanks for the response
I couldnt find anything to that effect at the dell website, and I have long lost the CDs.
If anyone has the utility, could you please help me out?
I thought something would still have been visible in system properties though?
Thanks
Scott
Default 09-21-2011, 02:41 PM
here.....it was VERY easy to find:
Drivers & Downloads
just click on applications....its the 1ST one listed
Default 09-21-2011, 07:17 PM
honestly thats one of the first things I installed, but it didnt help. I found an old image I had archived of the first XP installation and recovered the utility from there
problem solved, thanks for the help
Default 09-22-2011, 05:56 PM
Actually, try this one instead. The one Rich points you to does not, in fact, include the wireless select switch, despite it saying it does.
« OS X Boot problem... | MERGED AC power disables when battery hits 100% charge. »
