Cool 05-21-2011, 12:13 AM
Good Luck, Windows does not like to installed on a USB, you can install it FROM a USB but installing it TO a USB will be a problem....Microsoft sees to this..remember that installing windows will cause the system to re-boot a couple of times and this way the install will not be able to continue, registry files need to be updated wont work...but Good Luck to ya anyway
Default 05-21-2011, 12:27 AM
Yes, once the OS is loaded you can use the SD slot for whatever you want.
dew2 dew2 is offline
Default 05-28-2011, 11:51 PM
Originally Posted by Daveswaves View Post
Thanks Steve. Update, I purchased a bios code from ebay which worked nicely, I was able to get back into the bios and clear the password. Unfortunately the HDD password is now set. It seems that when the bios password fail routine runs it sets the HD password to active status, thus protecting your data if the lap top is lost. Good system. Looks like I will be replacing the hard drive. I will only be using this notebook for one application, on the fly tuning of a 2 stroke efi outboard engine. Has anyone had success just removing the HD and booting from a usb.
Do you need help with a outboard? I can help with OMC.
« battery not charging | 3-5 min delay before starts »
