waddo2011 waddo2011 is offline
Default Fixed HDD: None / Dell Mini 9 not detecting SSD - 04-17-2011, 04:30 PM
Hi there everyone...
I've currently got a Dell Mini 910 which was working great for a good few months then one day I booted it up and an error appeared saying "No operating system found"
I tried formatting but unable to using Windows XP cd's as it constantly says certain files are missing during setup process. I eventually decided to take out the 8GB SSD and get a new 16GB SSD to replace it. Swapped it over but now the BIOS doesn't recognise the new 16GB SSD, it just says "Fixed HDD: None"
It's a Brand new drive and I have no idea why it can't be detected in BIOS. Is there any option I need to change in the BIOS for this new drive to be recognised or will I need to update the BIOS?
Thanks for any ideas/help you can give
Default 04-17-2011, 05:33 PM
Try removing and replacing the SSD - it may not be in the socket correctly. No BIOS update should be needed. What is the brand and exact model of the SSD you bought?
« Missing Operating System error - goes away w/ battery unplug ?? | broken wwan?? »
