se7enty se7enty is offline
Question Missing Operating System error - goes away w/ battery unplug ?? - 04-13-2011, 01:46 PM
i've read the other seemingly relevant threads but none match my situation, and the one that might has a dead link to a download.
i have the mini 9 & had installed osx. it ran fine for a year, then i sold it to my office to use for presentations. of course then it got really squirrely so we decided just to put xp back on, using the original disc that came with it.
the format & reinstall went fine, no errors. it booted up fine. i start installing drivers (trackpad first) & after it tried to restart i get the "Missing Operating System" error. i turned it off & on several times getting the same message, then turned it off & unplugged the battery for about a minute. it booted fine after that. now it won't restart without doing the same battery disconnect thing. it has to be longer than 30 seconds too.
from looking around the internet, it seemed that reflashing the bios might help, but every time i do that i get the "your bios is current or newer than the one you're trying to install".
i don't know what to do now. the link to download in this thread Dell I910 Mini/Vostro A90 USB Key Drive flashBIOS Utility is dead.
i should add that i upgraded to a 32gb ssd prior to installing osx.
please help!!!! i feel like a retard for selling them this computer & now it doesn't work properly.
« Runcore 64 SSD heating up? | Fixed HDD: None / Dell Mini 9 not detecting SSD »
