bsiegler bsiegler is offline
Default 03-22-2011, 01:29 AM
Correct. I picked up a 16GB microSDHC Class 10 card for like $24 way back when, and this cool as hell Microsd USB dongle that takes the card inside the actual USB connector. Amazingly small, and it was $1.99 shipped from China for 3. Not sure how they heck they do it.
I fumbled with the instructions and accidentally messed up the host computer's boot, which I fixed. The instructions are not great at all, but its the fact that it can be done which is exciting.
You can always try the portable hackintosh drive:
Lifehacker, tips and downloads for getting things done
Originally Posted by holmes4 View Post
If it's a Mini 9, it will not boot from the SD slot, but can boot from a SD card if you use a USB card reader.
« SSD not writable | Golden Sombrero on STEC SSD's »
