Steve Hempell Steve Hempell is offline
Unhappy Fem32gfdi - 02-07-2011, 02:56 AM
Installed FEM32GFDI (the original STEC Died).
Running BIOS A06. SSD recognized in BIOS as FEM32GFDL - (PM)
Under BIOS Boot section Hard Drive ! FEM32GFDL. Does the exclamation point have a meaning?
Using an external I/O Magic DVD player, and reinstall disc from Dell - ( Green - Reinstallation CD MS XP Home Edition SP 3 for Ultra Low Cost PCs) - appears files are copied to SSD, install initializes and reboots only to start from the beginning.
Is this a driver problem or SSD problem?
Others here seem to have had no problems with the SuperTalent SSD.
Sorry if this is a duplicate as my first post got lost??
Default 02-07-2011, 02:36 PM
An exclamation point next to a bootable device in the Mini 9's BIOS means that it's disabled. Hit "Shift + 1" while the device is highlighted to toggle.
Default 02-07-2011, 08:24 PM
You sir are a guru!! I have spent days on this. On the upside, I learned BARTPE and NLite. XP loaded fine from a Nlite produced CD.
Thank You!!
« Installing new SSD | bios does not let me select boot device. »
