hmsrolst hmsrolst is offline
Default Problem with Atheros 802.11n Adapter - 01-15-2009, 12:06 AM
I upgraded my Mini9 with an Atheros 5008 card manufactured by AzureWave. No problem with the install and everything seemed to work fine. I primarily use my Mini9 to stream video with a Slingplayer. It works fine for somewhere between 45 minutes and an hour and a half at which point it always bluescreens with a message "NMI: Parity Check/Memory Parity Error." It's definitely not the RAM, because only switching back to the stock 802.11g fixes the problem. Searching the web suggest it's a defect in the adapter, but I'm not sure it's not a compatibility issues. Has anybody else had a problem like this and do you have any suggestions? Thanks.
specv specv is offline
Default Re: Problem with Atheros 802.11n Adapter - 01-16-2009, 06:37 PM
the wireless card is NG. Its highly doubtful you will find that its a hardware compatibility issue
« USB Bluetooth problem Sorta fixed | cant clone drive to runcore »
