Exclamation Computer will not charge or draw any power - 12-28-2010, 01:08 PM
This is not the battery. The white light will light and then the yellow will when I push the power button, but nothing happens when I plug the cord in. There is some give when i jiggle it around. Is there any home remedy? Failing that can i just pop my ssd out and plug it into another computer to gain access to my stuff?
Thanks
Default 12-28-2010, 03:32 PM
The SSD is not compatible with anything else. MyDigitalDiscount sells a special USB enclosure for these cards - $30.
Default 01-20-2011, 06:20 PM
I had the same problem. I replaced the power jack, but that didn't fix the problem. My DM9 is dead now. Its been like that for 6 months or so. I check in here from time to time to see if there is a fix yet. I eventually bought a new Acer Aspire one for $180 on Black Friday. That is probably the cheapest and less frustrating fix.
fokaiISmalones's Avatar
Default 01-22-2011, 06:53 AM
my acer would have the same problem i say its the power source. either the cord or the motherboard.
with my acer the quick and easy fix solution was to have the cord at a special angle being held up by something like a small peice of wood to one of the pink erasers.
some times that wouldnt work so i took a screw driver and carefully bend that nub thats in the hole(dirty jokes) and my power cord would work with or with out the special technique i stated above.
the slow and painfull technique is to soldier a new one from a used or broken laptop which i got from ebay.(it had a 8gb ram and mines only came with 2...score!)
dell mini 9|Windows xp home|1GB ram|bluetooth| dying to mod it!
acer ex4420|vista ult|8gb ram|
power issue
« Diagnosing SSD problems (runcore) | Screen resolution issue, tried all the help i found on this site too :o( »
