lashton lashton is offline
Default Dead dell - 11-27-2010, 05:58 AM
I had my dell on in the car and got pretty hot (software says 62 deegrees celcius) and now when i start it up, it says the SSD is there but wont boot of it and tried to boot via Network, what could be the problem?
In the BIOS it says thaqt the SSD is there but disk size is 0MB is it stuffed, and are these really that useless with a little heat?
Default 11-27-2010, 01:50 PM
Heat does seem to be a weakness of these - and if the SSD reads as 0MB, it is toast, literally in this case. But the reading you have of the temp is from the CPU, and 62C is normal for that. I doubt the heat was a direct factor.
« Battery not charging... | Battery accidentally discharged, now battery won't charge at all »
