Eddy Eddy is offline
Default HDD Size: 0mb - 10-13-2010, 03:10 PM
hello people, I have a problem of the mini 9 bios shows me the following things: Fixed HDD: 32GB STEC PATA-(PM)
HDD Size: 0MB
It is damaged the HDD?
Default 10-13-2010, 04:24 PM
Yes, your SSD is toast.
judyp judyp is offline
Default Dead Runcore SSD? - 10-13-2010, 11:19 PM
With my Runcore 16GB plugged into my desktop using the USB adapter, it says the SSD is working properly but shows no free space & no used space and no files even though I had used it for almost a year on the mini 9 using Win 7.
Does that mean it's toast?
Default 10-14-2010, 11:44 AM
sounds like its dead....another SSD bites the dust
dell mini 9, um-ssd 32gb fail
« Mini 9 Operating System Not Found - Replacement SSD? | Dell mini 910 will not re-format HELP!!! »
