JMalam JMalam is offline
JMalam's Avatar
Default Dell Mini 9 SSD Bad Sectors? - 09-19-2010, 12:27 PM
My Dell Mini 9 SSD (standard 16GB) is not working - I cannot read from it / write to it / partition it.
I 'zeroed out' the disk when I was attempting to install OSX in Disk Utility - is this what broke it?
I've run some diagnostics from a CD and it appears there are 'bad sectors' but no program will repair them.
Is there anything I can do? I cannot return to Dell or seller as it was bought new via eBay. If there is no fix for my existing drive, will replacing the SSD with a new one fix the machine?
I've spotted this SSD, is this a good one: KingSpec IDE PATA Mini PCIe 32GB SSD TO Dell Mini 9 Akc on eBay (end time 14-Oct-10 12:17:14 BST)
(I don't want to spend too much money on a RunCore or similar.)
Dell Mini 9 | Mac OSX 10.5.6 | 16GB SuperTalent SSD | 1GB RAM | .3MP Cam | Bluetooth | |
grassle grassle is offline
Default 09-19-2010, 01:56 PM
in another thread I got told kingspec were not really good, have no own experience, though.
Default 09-19-2010, 02:17 PM
You've somehow fried your SSD. This is a rather common symptom and there's nothing you can do about it. I don't recommend Kingspec. If you can't afford RunCore, then look at SuperTalent (the GFDL series, not GFHL).
lswartz lswartz is offline
Default 09-20-2010, 11:53 AM
Unfortunately, I believe holmes4 is correct.
I would try Ubuntu on a thumb drive to see if it can see & repair your SSD. I have had good luck with Linux where windows couldn't even see the HD.
« no audio problem | Dell Mini Won't Power Up »
