Auntie George Auntie George is offline
Default Broadcom WiFi Issue - 07-29-2010, 01:38 PM
Well, for the last year my Mini 9 has been working great running XP. Until yesterday when my Broadcom Arcadyne Wireless LAN disappeared. I click on device manager and it's not listed. I go into BIOS and LAN is activated and all looks OK. Obviously, my wireless capability has gone. So I re-installed the driver and get this message:
"No compatible hardware found. The software you are attempting to install is not supported on this system. The software will not be installed"
I can't fathom it out. How can the hardware just disappear? Any help greatly appreciated, thanks.
Default 07-29-2010, 04:40 PM
To help diagnose the problem, I'd reboot into another OS and see if it can see the wireless card.
Specifically, I'd use Linux (a Live CD/USB is fine, it doesn't need to be installed to the SSD) and run "sudo lshw -C network" in a terminal. That'll give you a listing of network hardware. A typical Mini 9 will have two entries, one for wired and one for wireless.
Here's my explanation of the command:
"sudo" = super-user do = run following command with admin privileges
"lshw" = list hardware
"-C network" = tells lshw to just list network devices
« Urgent Help Needed SSD replaced and not working :-( | Buzzing electrical noise »
