(#4)
(#5)
(#6)
| Junior Member Posts: 2 Join Date: Aug 2010 | Quote:
(#7)
(#8)
| Junior Member Posts: 6 Join Date: Jan 2011 | well i used this method (usb) with a regular windows xp to do a clean install there are programs out there that will alow you to take the cd/dvd image and put it on a usb so you can do a clean install. im not sure if i can post the name on this site because im new. but make sure that you take any password to access the computer off (bios or user) im not sure if it even matters because non of my lappys have passwords to acces them ![]() acer ex4420|vista ult|8gb ram| |
(#9)
| Super Moderator Posts: 2,883 Join Date: Aug 2009 Location: Upstate New York, U.S of A. | the USB flashdrive will work fine....I used this exact utility to load Win XP Pro and Windows 7 on my Mini 10 and I now dual boot both of them you can use this utility to load any version of Windows on to a USB stick link: RapidShare: 1-CLICK Web hosting - Easy Filehosting screen1 ![]() screen2 ![]() instructions are here: WinSetupFromUSB – Install Windows XP from USB Flash Drive « myeeeguides.wordpress.com you can also select Vista or Win 7 also just make sure you click on "bootable" then also click on "rmprepusb" to get to the second screen after you create the USB flashdrive....make sure that you also go into the BIOS on the Mini and enable the boot options for "Legacy USB" to boot to the Flashdrive iPad 4 (64gb),Targus Versavu Case |
(#10)
