Solo Solo is offline
Unhappy Runcore 64gb Issue - 01-04-2009, 04:03 AM
I've been trying most of today to install my new Runcore 64gb SSD on my new Dell Mini 9. Because the Runcore didn't come with a mini USB cable, I installed it in place of the stock SSD and tried to install Windows XP from the disks that came with the computer. After about 5 minutes, the install program would stop with a long error message telling me there is a problem with my hard drive...remove any hard drives recently installed and run chkdsk /f. I tried removing the drive and reseating it, but kept getting exactly the same error message.
So I reinstalled the stock SSD then went to Walmart and bought the mini USB cable referred to in another thread. When I plug the Runcore drive into any USB port, including all on the Mini 9 and those on my other computers, I get an "unrecognized USB device" error.
I'd sure appreciate any suggestions. Thanks!
Default Re: Runcore 64gb Issue - 01-04-2009, 03:17 PM
I assume you actually got a MicroUSB cable.
It sure sounds as if the drive is defective. I'd suspect the cable but if it didn't work installed into the Mini, that's not it. Contact MDD.
